Andy-J
Oct 16, 2017Initiate
Continous backup stopped working
Hi,
I've just updated my Readynas 212 firmware to latest version 6.8.1 and have now discovered the continuous backup setting no longer works. Before the update any files/folders created or modified were automatically backed up within a few minutes. Now I have to rely on a separately scheduled daily backup which works fine. I have another two NAS units requesting updates but obviously I'm now reluctant to do this.
I’ve tried deleting & recreating the backup schedule (Continuous mode) with no success.
Any help or advice would be appreciated.
Thanks Andy J
- jozifaAspirant
I have the same problem with my ReadyNas 312. New firmware on iphone version 2.0.0(2027) is not backing up, showing uploading, but not progress. ReadyNas firmware is updated as well.
- BingkeXNETGEAR Expert
Hi jozifa,
What is your iphone's ios version? Which network does you iphone use? Same LAN with your nas, different LAN, or 3G/4G?
Would you please try to disable and enable backup again?
Best Regards.
- jozifaAspirant
Hi,
Sorry for late reply due to my email setting error. My iphone 5s version is ios 11.1.2. The media backing up is not uploading. It is on same LAN. The media backup on my other devices, ipads, iphoneSE seems working. I also have tried reset, en/disble it and even reinstall the Readycloud app.
Hello Andy-J,
Welcome to the community.
Which application did you use to "the continous backup"? Readycloud Windows/MAC app or iOS/Android readycloud app or any where?
Best Regards.
- Andy-JInitiate
Hi,
Thanks for getting back, I access Readynas vault via Windows10 / Chrome https://vault.readynas.com/account/login Here I manage the backup schedules & types. I've just applied latest firmware ver 6.9.0 in the hope this will fix the problem but unfortunately not. Still no continous backup feature. I can only rely on daily backups at the moment.
Thanks
Andy J
