ramanj123
Aug 09, 2018Aspirant
Could not connect to Readycloud
Hello,
I have a readynas 516. Current version is 6.9.3. I have Readycloud in switched off mode. If I try to switch on by sliding, it asks my email and login password, once I give, it says "Ther...
- Aug 21, 2018
Great! I had to remove a very old config file so the system could generate it again when you enabled ReadyCLOUD.
Aug 10, 2018Guru - Experienced User
When you look at the cloud page on the NAS, are you seeing the two green checks (one for internet available, the second for services available)?
- ramanj123Aug 16, 2018Aspirant
On cloud page of ReadyNAS, I am not finding any green check. Please see the snapshot attached herewith.
janakiraman
- mdgm-ntgrAug 17, 2018NETGEAR Employee Retired
Please send in your logs (see the Sending Logs link in my sig).
- ramanj123Aug 17, 2018Aspirant
Hi
Please check your email for the system logs.
janakiraman
- StephenBAug 17, 2018Guru - Experienced User
You need to turn the ReadyCloud service on before you'll see the green checks.
