ramanj123
Aug 09, 2018Aspirant
Could not connect to Readycloud
Hello,
I have a readynas 516. Current version is 6.9.3. I have Readycloud in switched off mode. If I try to switch on by sliding, it asks my email and login password, once I give, it says "Ther...
- Aug 21, 2018
Great! I had to remove a very old config file so the system could generate it again when you enabled ReadyCLOUD.
Aug 10, 2018Guru - Experienced User
When you look at the cloud page on the NAS, are you seeing the two green checks (one for internet available, the second for services available)?
ramanj123
Aug 16, 2018Aspirant
On cloud page of ReadyNAS, I am not finding any green check. Please see the snapshot attached herewith.
janakiraman
