ramanj123
Aug 09, 2018Aspirant
Could not connect to Readycloud
Hello,
I have a readynas 516. Current version is 6.9.3. I have Readycloud in switched off mode. If I try to switch on by sliding, it asks my email and login password, once I give, it says "Ther...
- Aug 21, 2018
Great! I had to remove a very old config file so the system could generate it again when you enabled ReadyCLOUD.
ramanj123
Aug 16, 2018Aspirant
On cloud page of ReadyNAS, I am not finding any green check. Please see the snapshot attached herewith.
janakiraman
mdgm-ntgr
Aug 17, 2018NETGEAR Employee Retired
Please send in your logs (see the Sending Logs link in my sig).
- ramanj123Aug 17, 2018Aspirant
Hi
Please check your email for the system logs.
janakiraman
- mdgm-ntgrAug 17, 2018NETGEAR Employee Retired
Please go to System > Settings > Support and PM me the 5-digit number that you then get.
- mdgm-ntgrAug 19, 2018NETGEAR Employee Retired
The code you sent didn't work. Please disable Secure Diagnostic mode and re-enable it and let me know the 5-digit number that you then get.
- ramanj123Aug 20, 2018Aspirant
Hi,
I did the same as you told. Again it has generated 52328 only.
With regards,
janakiraman
