ramanj123
Aug 10, 2018Aspirant
Could not connect to Readycloud
Hello,
I have a readynas 516. Current version is 6.9.3. I have Readycloud in switched off mode. If I try to switch on by sliding, it asks my email and login password, once I give, it says "Ther...
- Aug 21, 2018
Great! I had to remove a very old config file so the system could generate it again when you enabled ReadyCLOUD.
mdgm-ntgr
Aug 21, 2018NETGEAR Employee Retired
ramanj123
Aug 23, 2018Aspirant
Hi,
Now, Ready cloud is on and services tickmark is also there next to Internet. I have created a user and group in accounts. I have registered also. I have downloaded the readynas cloud app and installed on my windows machine. Readycloud desktop is running in my system. When I log in with my credentials, it is logging in but could not discover my readynas. I have made discovery on physically in ReadyNAS. But still, it says "currently you have no registered devices" in readynas cloud app. What is the problem still.
janakiraman
