santapaija
Dec 04, 2014Aspirant
How to connect local user and Readycloud user accounts
Hi
Is there any way to logically connect a local user account and ReadyCloud user account?
I want to do this so that a local user can access from remote using ReadyCloud and access his Home folder.
Right now ReadyCloud user gets his own Home folder and can not access his files in his local user account Home folder.
Thank you very much for any suggestions.
Sant
Sant
- NhellieVirtuosodo you want to use the same username for a local (pc or nas?) user and the readycloud user?
It might already be possible on 6.2.0 (needs confirmation on this one)
-what I'm not sure if its possible to connect them - NhellieVirtuosoit appears that this is not possible. I just tried it. Does not let you add a local user if it is already a readycloud user.
- ScottChapmanApprenticeYea, it's two bad that you have two separate user worlds. Would be nice to enable some kind of association between the two so it can be consider the same user either on LAN or cloud.
- Apr 16, 2020Anonymous
