bkxit
Apr 28, 2021Tutor
online vpn disconected ????
Hi All .. All has been working fine up untill about a week ago. Now desktop app for backup and sync will not connect a vpn to the NAS. It sees the NAS as on line ok but cant connect VPN . Have ...
JohnCM_S
Apr 28, 2021NETGEAR Employee Retired
Hi bkxit,
May I know what is the OS of the computer? Do you also get the same problem when you try it on other computers?
You can also try temporarily disabling the security software on your computer and see if you will still get the same issue.
bkxit
Apr 28, 2021Tutor
Hi John.
many thanks for the reply..........
Edition Windows 10 Pro
Version 20H2
Installed on 14-Apr-21
OS build 19042.928
Experience Windows Feature Experience Pack 120.2212.551.0
Need it to work on the PC its on as its the work one...
Have found a possible fix from Brian L
Disable IPv6 on the active network tab ...
Will try in the morning and report back.
Did disable all security .......... no go..
- bkxitApr 28, 2021Tutor
Hi All.
Ok ............. Still not working
NAS is seen as on line , But still not able to connect VPN
Ihave tried the" Disable IPv6 on the active network tab ..."
Still no go , Was all working fine a few weeks ago.
Any ideas anyone ... Help..:smileysad:
