TT_DE
Aug 21, 2022Luminary
ReadyCLOUD aborts uploading pictures from Iphone - has to unlog and login again
Iphone 13 an readycloud app version 2.1.2 (2337) Upload photos to NAS via readycloud app keeps aborting with error for about a month. error messages: The server is not responding or Unexpecte...
Aug 30, 2022Guru - Experienced User
TT_DE wrote:
StephenB : as you are known as the community guru any guidance to solve this issue would be highly appreciated 🙂
Neither Sandshark nor I use ReadyCloud, so this isn't something we can offer much advice about.
Personally I use Resilio Sync to back up my iPhone photos (Resilio Sync is also installed on a PC, I'm not using the ReadyNAS app). I use OpenVPN (hosted in my Orbi router) to allow my iPhone to access my home network while away.
TT_DE
Aug 30, 2022Luminary
Thx for your feedback. Will have a look re the applications you mentioned.
- StephenBAug 31, 2022Guru - Experienced User
Sandshark uses ZeroTier for the VPN - also worth a look. If you are using the file sharing features of ReadyCloud, then you might check out NextCloud (available at rnxtras.com).
