Retired_Member
Jul 05, 2017Re: ReadyNAS 204 - MyCloud and ReadyCloud aren't working.
Well, I just uninstalled MyCloud and installed ReadyNasRemote again and today it worked... the last 20 times it did not. Tried both back and forth. However..... now there is an error when I try to lo...
- Retired_MemberJul 11, 2017
Well, I am sorry you did not come up with a solution for this but I am glad to say that I have now gotten it working.
I logged into my ReadyNAS RN102 at home using TeamViewer and connected locally to the Netgear Raid.
I then removed my ReadyCloud account from the Ready NAS Cloud tab and then rebooted the drive.
I then added the same identical account back in to the Cloud tab, rebooted again and now I am able to connect remotely to the online ReadyCloud.
Cheers!
Jul 06, 2017Guru - Experienced User
Retired_Member - did you post this on the wrong thread?
If so, let me know if you want me to move it.
- Retired_MemberJul 06, 2017
If you feel it is in the wrong place, please go ahead and move it but I don't believe so. This problem was apparent in both MyCloud App and NetgearNas Remote.
- StephenBJul 06, 2017Guru - Experienced User
This thread is about Windows 10 SMB backup jobs failing. I will split your's off into it's own thread.
What firmware is running on the NAS? You shouldn't be using Remote with OS 6.
Is mycloud working now?
