Anonymous
Jul 05, 2017Re: ReadyNAS 204 - MyCloud and ReadyCloud aren't working.
Well, I just uninstalled MyCloud and installed ReadyNasRemote again and today it worked... the last 20 times it did not. Tried both back and forth. However..... now there is an error when I try to lo...
- AnonymousJul 11, 2017
Well, I am sorry you did not come up with a solution for this but I am glad to say that I have now gotten it working.
I logged into my ReadyNAS RN102 at home using TeamViewer and connected locally to the Netgear Raid.
I then removed my ReadyCloud account from the Ready NAS Cloud tab and then rebooted the drive.
I then added the same identical account back in to the Cloud tab, rebooted again and now I am able to connect remotely to the online ReadyCloud.
Cheers!
Anonymous
Jul 06, 2017If you feel it is in the wrong place, please go ahead and move it but I don't believe so. This problem was apparent in both MyCloud App and NetgearNas Remote.
Jul 06, 2017Guru - Experienced User
This thread is about Windows 10 SMB backup jobs failing. I will split your's off into it's own thread.
- StephenBJul 06, 2017Guru - Experienced User
What firmware is running on the NAS? You shouldn't be using Remote with OS 6.
Is mycloud working now?
- AnonymousJul 06, 2017
StephenB wrote:What firmware is running on the NAS? You shouldn't be using Remote with OS 6.
Running 6.7.5 Firmware. Not running OS 6 at all. Running Windows 10. iOS version is10.3.2
MyCloud does not work on my PC now but ReadyNAS Remote does. Like I said, I have tried both back and forth and then finally out of the blue yesterday the Remote started to work. Then my phone refused to wok and no I can't access the Online site.
It starts to load and then gives the error: 6001010106
6.7.5 -- OS 6 firmware on the NAS.
MyCloud is Western Digital's NAS cloud, so I am confused.
