jbuchal
Jan 10, 2020Tutor
ReadyNAS Can't Connect to ReadyCloud
I just switched internet providers and lost Readycloud access to my NAS. I dimly recalled that I would have to set port forwarding on the new modem to do this, but when I forwarded Ports 80, 443 and...
- Jan 10, 2020
Hi jbuchal,
Please try logging in to the NAS local admin page then go to Cloud tab, then check if the Internet and Service have a green checkmark on both.
If one or both of them does not have a checkmark, you may try assigning your router's IP address and 8.8.8.8 for the NAS DNS servers.
Jan 11, 2020Guru - Experienced User
jbuchal wrote:
System > Cloud is not a choice. ]
Cloud is it's own top level tab (not under system). The checkmarks should be shown there.
jbuchal wrote:
and has a header over the list of these services that says “Internet Unavailable”.
And you need to fix that first. Once you do the checkmarks should show up on the cloud Tab.
As Sandshark says, it is likely that you assigned a static IP address to your NAS, and perhaps used your old ISPs DNS server when you set that up. That won't work if you have a new ISP. Adding 8.8.8.8 (Google's public DNS server) and/or 1.1.1.1 (Cloudflare's public server) to the DNS server list in the NAS would resolve it.
Another approach (better IMO) is to use DHCP in the NAS and reserve the IP address in your routr.
jbuchal wrote:
but when I forwarded Ports 80, 443 and 6300 to the device's IP address, it still would not connect. (I would prefer not to forward Port 80, and wasn't sure it was necessary.)
You shouldn't need to forward any of those ports to use ReadyCloud, so I suggest removing the forwarding for now.
BTW, what firmware are you running?
jbuchal
Jan 12, 2020Tutor
Putting in the gateway and 8.8.8.8 IP addresses for DNS servers solved the problem. Thanks for a quick response.
The "green check mark" thing confused me because the software (firmware version at bottom of first post) does not show a checked/unchecked box status. The top level Cloud tab says either that there is no internet access, or shows it as working with a green check.
I will experiment with removing port forwarding; I must have remembered that from some older problem. Thanks again.
- StephenBJan 12, 2020Guru - Experienced User
Glad it's resolved.
I'd remove them all. If ReadyCloud fails, then you can forward 6300 - it doesn't need the others. You shouldn't need to forward it, because the NAS is making an outbound connection to ReadyCloud (which is allowed by default in almost all home routers).
Port 443 can be forwarded if you want to access the NAS remotely. If you do that, make sure you have a strong admin password. Another option there is to use a VPN - many routers now provide OpenVPN support.
