Mike101
Nov 16, 2015Tutor
Ready NAS connectivity backup and sync issues
Please excuse my ramblings. With more knowledge I could be more concise.
I am trying to use the ReadyNAS Cloud App to synchronise files and folders (and backup) a PC over the internet with Windows 7
In the past, on occasions, I have been able to access and use the NAS with the App and have it sync the files with my PC (working as I believe it should work) However:
Issue 1 (intermittent)
Sometimes I have had problems with my App initialising. Clicking the app button in the tray, Initialising starts off the box disappears and then nothing happens.
However if I go via the Web Portal I can see and access my files.
Issue 2 (intermittent)
When the Ready Cloud App does connect and I can see the NAS and the Files on the NAS. The App tries to sync then shows a red cross when it decides it has failed to sync. the folders.
If I try to look, open or explore the files by clicking on a NAS Folder in the app I get the following PC message: User Account Control
Do you want to allow the following program to make changes to this computer C:\windows\Syswow64\explorer.exe \\2.204.86.62\"my local file name on readynas" There is also a yellow triangle obscuring part of the tray icon.
2.204.86.62 is not the IP address of my ReadyNas. Is this an official "portal" for ReadyNas? (Upon a Google search it came up with the IP location in an uninhabited wooded area of Hungary according to Google Maps. However I think this might be spurious.)
How do I know if syswow64\explorer.exe \\2.204.86.62\"my local file name on readynas" is safe and not hijacked by hacker etc. Can I allow the changes.
Also sometimes I get the red cross for sync. with "off line, Readycloud is not available". However if I go via the Web Portal I can see and access my files. I assume this is part of the same issue.
Issue 3 (intermittent)
When I can access the NAS folders and the App confirms it has synchronised the folders with green tick, the synchronisation is not working. Looking at the file it is still recorded at an historical date. Even if I make changes to the file on the remote PC and save them they are not updated/synced.
All three issues seem to occur on random days by which I mean there appears to be no pattern. However the last sync date that I have is 8 October 2015 ie it hasn't worked properly since then. Even though the App shows a green tick sync up to date
Any help would be greatly appreciated
- BarcaXtremeAspirant
Hi. I've got a similar issue also.
I have a ReadyNas 104 FW 6.4.0
Used to be able to access the NAS from anywhere using ReadyCloud.
Now the option for ReadyCloud is deactivated, instead I have ReadyDrop. I can't access the Readydrop web page, keeps saying unavailable, and Readycloud doesn't see my NAS since I can't activate the option, if I try to activate it, I get a message that says
"ReadyDrop service was deprecated as of ReadyNAS 6.2.0"
So now, I can't used ReadyCloud, and ReadyDrop doesn't work either, so essentially I have a NAS that's only accessible through my local network.
I'd appreciate any help.
Babak
- DamiaGuide
If you cant togle on redycloud on nas you can try to reinstal os it will reset your password to admin but it may help with tagling services on
It dosnt delate any data
Boot option legend
- DamiaGuide
I have same issue with syncing tech support is working on it i hope as no solution was found after 5 hours of remote access by tech support will share solution when i will find out
- JennCNETGEAR Employee Retired
Hello Mike101,
Welcome to the community!
Please include the ReadyNAS model and FW version of the NAS.
- Mike101Tutor
Hi JennC
"Please include the ReadyNAS model and FW version of the NAS"
Model is ReadyNAS104, FW version is 6.4.0
Any Help Greatly appreciated
Kind regards
Mike
