egoldman2
Oct 16, 2018Follower
ReadyCloud App not connecting - VPN connectivity issues
For all of today, I have not been able to access the remote network I have the ReadyCloud app installed for on my Windows laptop. I can log onto the app and it gives me the following message "Online ...
SkylerOpenSky
Oct 16, 2018Aspirant
I suspect this is Netgear's server causing issues today. I too have noticed all day today that our ReadyCLOUD app will not establish a VPN connection. However if I VPN my laptop to the corporate network, I can establish a local conneciton. I've rebooted the ReadyNAS, corporate firewall, checked the Cloud internet status (green), etc. Not sure how to report service outage or if other users are havin this issue today (16-OCT-18).
- nextwavepcOct 18, 2018Guide
any update on this? we have several devices and they are all down.
- SkylerOpenSkyOct 18, 2018Aspirant
The abillty to connect via VPN started working for us yesterday and was only down for 1 day. You should log out and log back in to your ReadyCLOUD app on your desktop. Once we did the logout and login, it worked again. Hopefully this was just a fluke for a day.
- JohnCM_SOct 18, 2018NETGEAR Employee Retired
This issue should be fixed already. In most cases, you need to reboot the NAS to reconnect to ReadyCLOUD. In 6.9.3 and above, you can manually turn off ReadyCLOUD/Replicate and re-enable if you are not reconnected automatically.
