freddie802
Mar 22, 2015Aspirant
Readycloud Client GUI not displaying Win 7
Hi, I have a readynas rn104 that is working fine. The reaycloudn client on my windows 8.1 works fine. I have installed the client on my win 7 pro and when I open the client all of the folders say opening with a blue circle. I am unable to sync my readydrop folder between this computer and the win 8.1 computer. Has anyone seen this behavior? It shows that I am logged in but I can't do anything with the interface. I have turned off my firewall with the same result, I have installed the latest java and adobe air updates, I have the latest flash player etc.
- RXLuminaryDo you have any software firewall / anti-virus installed in your Windows 7 PC? If yes, try to disable it. :)
- freddie802AspirantDisabled firewall & anti virus. No change. When I click on the tray icon it says opening when I hover over the folder name. The other links work such as web interface etc. but I can't get to any options for the individual folders.
