kburton0
Nov 25, 2014Aspirant
ReadyCloud Desktop App
When will the ReadyCloud Desktop App for mac become available?
- MacRobAspirantWell I was bored so I did download the version that shows up on the readycloud webpage. It is a newer version and it does not say beta anymore. For me on ElCapitan it is working fine. (I do not use it for backups soo... ?) I do use it to connect and mount the various volumes I have. They also cleaned up the graphics glitches with the checkboxes.
- daveryan66Aspirant
Excuse us for asking moderator do Netgear or do they not have an app that works for MAC El Capitain?
As a point of reference I managed to get my money back from WD because their software did not operate at all correctly.
Your software did work in a fashion, but have change to Windows 10 on my PC and bought a MAC - I downloaded what I thought was a MAC app but it just just keeps saying it is connecting. I would like to know before I spend too much time on it whether it work or not?
As a general comment what are you doing releasing beta version - do you think you're Microsoft or something? Most people just want to stream and back up and you need a beta version - hmm you must of seriously over cooked this app.
Excuse us for asking moderator do Netgear or do they not have an app that works for MAC?
- MacRobAspirant
So does anyone know what the current version of readycloud is? beta or otherwise?
I have 1.0.541.118beta. But when I was on the ReadyCloud web portal there was a link to download the ReadyCloud app. (It wasn't there last time I was on this page) it downloads a .pkg file dated Nov 6 2015 3:11pm, which is pretty recent. but there are no version numbers, and I don't want to install it and overwrite a working install with an old version.
This thread seems to have died in june, is anyone still paying attention?
- LeofwineTutorI'm double posting because I digressed in another thread not realising that this thread existed. But regarding ReadyCLOUD:
It has taken me a while to take the plunge as I have consistently failed to find any informative material about how ReadyCLOUD works on a Mac (I could not even find out how to download and install it) so, I have only just installed the beta of ReadyCLOUD on my Mac. I wanted to sync documents between two Macs so that the latest version was always on both but I can't really put my faith in it until I know it works and so far, I am unimpressed.
The ReadyCLOUD beta interface fills me with dread! At first, I thought that there were no check boxes next to the selections in settings but then noticed that the checkboxes are actually floating in midair between the ReadyCLOUD popup and the menu bar; to select them, you need to click the text and hope that the change actually applies.
I also encountered a near catastrophe because I clicked 'Backup Mac Folder' and then attempted to select a subfolder in the only perceivable way, by double-clicking a folder. Unfortunately, this initiated a backup of that entire (massive) folder and frantic clicking of the cancel button didn't seem to work - though it eventually did. It would be of great benefit to me to be able to backup more than just the main folders in my user folder - how can multiple users collaborate if only documents from a single user's account folder can be backed up?
I am, all in all, pretty disappointed with ReadyCLOUD. It was probably the main reason I switched to the RN102 which I recently bought. The website promotion gave the impression that ReadyCLOUD was up and running and not in an experimental, half finished state. - Maestro11AspirantThe App is not working perfectly, It some time still will come up with the VPN connection error and the only way I have been able to clear the problem once it start happening is to delete the app and re-install it.
I am not sure what causing it to happen as of yet, but when it does happen it only affect connecting from outside the home network. If the computer is on the same LAN and IP subnet it will connect without issue.
I been able to make it work every time as long as I log out of the app and then exit it before switching networks. I have switch back and forth between my home network and external network a number of times and it will connect each time, but I make sure the app is not running when I switch back and forth. I am thinking the issue may have happen is the app was running and possible I was still logged in when I switch networks. This may make sense if that is what happen. I will have to do more testing to see if I can make it fail again. - salamander1AspirantHello,
thank's it's work Correctly now.
Best regards - Maestro11AspirantBTW everyone there is a new version as of the 22nd of April, it is V1.0.589.151 I have not had a chance to test it to see if it fixes the problem with connecting outside the home network. Maybe someone else can give it a try and report back.
You can download it from the link I provided in the past. - Maestro11Aspirant
tetedeneud wrote: Hello Salamander,
I also come here regularly to take news from the readyCloud desktop application. It works on my side, but I often have to re-install the application...
At the same time, I use the remote application (available for Yosemite) to access my NAS. You can download it at the bottom of the page: https://remote.readynas.com
Best regards,
Tetedeneud
Originally this did not work, but I had an old version and they seem to have updated it since I last installed and it is now working. - Maestro11Aspirant
ryanasimov wrote: EskenderNG wrote: @Maestro
@ryanasimov
One thing that might help with the issue of being unable to connect via VPN from outside your home:
Does your ReadyCLOUD username contain upper-case letters? If so make sure you write your name exactly the way it was created (in terms of upper-case letters) when you log on. Or even better use a username with all lower-case only. This helps with some connection issues on the Windows Desktop App and the ReadyCLOUD Portal, might as well help on the Mac.
Bye,
Eskender
Thanks for the reply, but my username is all lowercase letters. I've tested the Mac version of the ReadyCLOUD app on many Macs and the result has been the same: Install, connect successfully, disconnect, then each subsequent reconnect attempt produces a "VPN Disconnected" error. Rebooting doesn't help, but reinstalling the app allows it to work again (for one connection, then a repeat of VPN error).
BTW, if the case-sensitivity of the username is a known issue it might be a good idea to put this in the installer or the release notes.
That pretty much sums it up, works once and avery time afterwards get an error and will not allow me to connect. Still have the problem today. I wish they would just fix this issue.
