Malinois31770
May 21, 2019Aspirant
ReadyCLOUD Desktop Client Failure : application display "Online (VPN Disconnected)"
Configuration :
RN102 :
RN102 Firmware 6.10.0 Hot Fix 2
2 disk WD Red (X-RAID)
Desktop Clients :
Windows 10 Pro x64 (2 different computer)
Hello, since 2 month my readycloud connexion doesn't work using the ReadyCLOUD desktop client (v1.17) which displaying this message : "On line (VPN Disconnected)".
I don't know what happening :
--> I've restart the NAS many, many, many time... no results.
--> I've restart my personnal Internet conneciton : no results
--> I've re-install the ReadyCLOUD client application : no results
--> Updating to the last firmware version have not resolved the issue.
--> ReadyCLOUD work from web browser and/or from the IPhone application .
Somebody can help me ?
Thanks
Hello Marc_V and anybody that have encountered the same issue....
As I've predicted, I've performed a FACTORY RESET of my ReadyNas (= ERASE ALL DATA :smileyfrustrated:) after, of course, have doing a backup (about 2 Tbs of data transfered...) on external USB storage. Now, all readycloud APIs are working well using the same user account (mine :smileyvery-happy: )
I hope the last release of ReadyNas OS are more stable and the problem will not coming back..
- Marc_VNETGEAR Employee Retired
Have you tried contacting NETGEAR Support through my.netgear.com?
Is the issue happening when you try to login on a different computer? Kindly check if you try to disable any security software you have on your PC.
Hope this helps!
Regards
- drhjorgensenAspirant
I have the same problem connecting through various PCs in various locations with a variety of routers/internet providers/etc
As i said, the strange thing is I can connect to one NAS but not the other on the same ReadyCLOUD account.This would lead me to believe it is not a PC-related issue, but something else (NAS? Router at NAS location? etc)
I haven't contacted Netgear support directly as the units are out of warranty and I figured my clients would need to purchase a support contract... may have to do that as a last resort.
- Malinois31770Aspirant
Hi drhjorgensen ,
I've the same problem than you : problem is repeated on several different computers.
I think the issue come from the NAS which is not a releable device. I've created a wasabi account to synchronize and backup my files. When I'll get the time, I will reset entyrely the device or change it by another model built by other provider.
I am disappointed by NetGear regarding treatment of this problem.That's all we can hope
This sounds exacttly like the problem I am having with several of my clilents devices... See here:
https://community.netgear.com/t5/ReadyNAS-Cloud-Storage/ReadyCLOUD-connection-problems/td-p/1747959
Is anyone able to help with this??
