mvetri
Apr 21, 2018Guide
ReadyCloud GUI not working (Desktop App) PRJNAME
I can no longer auto connect with the Ready Cloud App for Windows. I uninstalled the app, then reinstalled, and the interface titles changed and are variable of code and the interface looks weird.
I have been using the app for several years just fine. Something has changed. Does anyone know what the issue could be? I'm attaching a screen shot of the changed interface.
Thank you in advance.
- Marc_VNETGEAR Employee Retired
Hi mvetri
The issue seems to be related to Java versions installed on your computer. Have you tried installing the ReadyCloud desktop app on a different computer?
You may want to update the computer. Also please make sure the latest ReadyCloud app is installed
I have tried installing it (v1.16) on my Windows 7 PC but I don't have the same issue.
Regards
- mvetriGuide
Hi Marc:
Thank you for the reply. I am actually runny ReadyCloud app on 2 WIndows 10 PCs. One is an HP the other a Dell. I verified I have the most updated versions of Java and the ReadyCloud app installed on both PCs. The ReadyCloud APp works fine on the HP laptop but still does not work on the Dell Laptop.
Any other ideas of what it could be?
Hi mvetri
To be honest I am not really sure what's causing the issue since it works on your HP Laptop. I have several workstations as well but none of them gets the same issue as what you have.
It would be better if you can check your Dell laptop's System as it might be missing some components that is causing this.
Regards
