424User
Jan 09, 2018Tutor
ReadyCLOUD not uploading pictures from Iphone
I am unable to upload pictures from my Iphone (IOS) using the Netgear ReadyCLOUD app (version 2.0.0, (2027)). I have an ReadyNAS 104, running firmware 6.9.1. I’m not exactly sure when the problem ...
Saginus
Mar 18, 2018Aspirant
Netgear has the worst possible customer service .. I reported the same issue back in November 2017 and still no update.. idiots keep saying their engineering team is looking into it but morons have not been able to identify the cause and fix the problem. Can’t belive this is what we get for $250 router.
Marc_V
Mar 19, 2018NETGEAR Employee Retired
Hi Saginus
Welcome to the Community!
Are you using ReadyCloud on ReadyNAS or on a Nighthawk router? If you are using a router you will have to post to the correct board so they can properly assist you.
If you reported an issue with a ReadyNAS system do you still have your case number? if not, I would suggest contacting NETGEAR Support so they can assist you on testing a ReadyCloud app build if possible. It is important that user experience on the issue gets included on the investigation so they can properly create a resolution.
Regards
- SaginusMar 24, 2018AspirantCase number 29491377
NO UPDATE SINCE I OPENED IT. More than 3 months, hence the comment- worst possible customer service.
