EGokie62
Feb 22, 2015Aspirant
ReadyCloud not working - shows up as offline
Hi, I'm Eugene. I work for the Department of Defense here in the North Chicago area. I recently purchase a Netgear NAS RN102. Was able to get it setup. Enter the Admin panel. Was changing the ...
krazydav
Static IP has been a problem for some including myself. Try setting it to DHCP and see if it comes back. If so then this is an item that Netgear needs to address. Also, if even with IPv4 set to DHCP and if ReadyCloud doesn't right itself then also enable IPv6, also DHCP.
