Max_1968
Mar 19, 2013Aspirant
ReadyCLOUD not working ?
I have an ReadyNAS NV+ with 4.1.10 and an ReadyNAS Ultra 4 with 4.2.22 installed, both workinf fine in the same network as my windows PC. Just tried to use the ReadyCloud discovery feature, but none o...
techman05
Mar 10, 2015Guide
Follow back my other posts since there is a fix for potentialy getting it to work. If you bought it used someone might have not turned it off properly and mess it up.
Os 6 for readycloud is a bit easier to fix if you. discovered the device already. If you can turn off ready cloud on the device and disconnect on the readycloud page and connect to a account you should be golden for both.
If your having issues other than that you do have a business product and you do have free chat through your netgear account. They're are still pleanty of helpful people here to cover what chat may miss on if they lack.
Good luck for now.
Good luck for now.
