Max_1968
Mar 19, 2013Aspirant
ReadyCLOUD not working ?
I have an ReadyNAS NV+ with 4.1.10 and an ReadyNAS Ultra 4 with 4.2.22 installed, both workinf fine in the same network as my windows PC. Just tried to use the ReadyCloud discovery feature, but none o...
szkodnik_byd
Sep 19, 2015Aspirant
But is problem with working on new windows 10 - that netgear would fix it ??
netgear would wont to gave us redycloud, and dont develop ouer doftware ??
we should buy new 200 series and will be OK - but change NAS becouse is new version is idiotic
- billv686Nov 30, 2015Aspirant
ReadyCloud stopped working on two ReadyNAS NV+ units after receiving an email that the last firmware upgrade notice I received was not applicable to the NV+ V1 unit TODAY. Nothing else has changed, but the client can not login to the Netgear Ready Cloud any longer. I am using Windows 10 which has worked fine with the Remote access for the past few weeks. Whats the story????
Bill V
- StephenBNov 30, 2015Guru - Experienced User
Remote is actually different from ReadyCloud. ReadyCloud is OS-6 only.
