geekstar331
Dec 02, 2014Tutor
ReadyCloud replaces ReadyNAS Remote and other confusion...
The release notes for 6.2 says that ReadNAS Remote has been replaced by ReadyCloud and a ReadyCloud PC Desktop app... Unfortunately, I cannot get live help via Netgear support because I am outside of...
Nhellie
Dec 15, 2014Virtuoso
grimloch wrote:
I can't find any settings for ReadyCLOUD firewall. I've checked the windows software, ReadyCLOUD NAS settings, and my readycloud.netgear.com account. Where can the firewall be enabled/disabled?
So, upon looking it appears that there is a setting on the ReadyNAS Remote on the NAS that you can set a port number 6300 (default). Can you try opening port 6300 and forward it to the local IP of the NAS?
Edit*
this setting can be found at Cloud>ReadyNAS Remote>Settings>Security
