geekstar331
Dec 02, 2014Tutor
ReadyCloud replaces ReadyNAS Remote and other confusion...
The release notes for 6.2 says that ReadNAS Remote has been replaced by ReadyCloud and a ReadyCloud PC Desktop app... Unfortunately, I cannot get live help via Netgear support because I am outside of...
grimloch
Jan 08, 2015Aspirant
Nhellie wrote:
grimloch wrote:
I can't find any settings for ReadyCLOUD firewall. I've checked the windows software, ReadyCLOUD NAS settings, and my readycloud.netgear.com account. Where can the firewall be enabled/disabled?
So, upon looking it appears that there is a setting on the ReadyNAS Remote on the NAS that you can set a port number 6300 (default). Can you try opening port 6300 and forward it to the local IP of the NAS?
Edit*
this setting can be found at Cloud>ReadyNAS Remote>Settings>Security
I messed around with the port forwarding but it didn't help the situation. It would be really nice to be able to turn the firewall off like it was possible with the former Windows Remote standalone app. The same functionality would be nice to have in the Android/iOS apps, too.
