vandermerwe
Jan 27, 2017Master
Readycloud services unavailable
Two questions actually, I'm trying to set up Readycloud. Firstly when I toggle on Readycloud in the GUI, "Services unavailable", cannot attach device appears. I have a myNetgear account which is lo...
msavard07
Jan 28, 2017Aspirant
I have the same problem with a new RN104 behind a Netgear R7000. All running with latest firmware.
FramerV
Jan 29, 2017NETGEAR Employee Retired
Hi msavard07,
On your ReadyNAS cloud tab. Do you have (2) green check marks?
- vandermerweJan 29, 2017Master
Not sure about msavard, but I dont, one is green, one is red, I would assume msavard is experiencing the same problem?
- MalcolmTJan 30, 2017Apprentice
Seems this may be porttal related. My current ReadyNAS2120 has remained connected and authenticated but I can't access it using the desktop client, and I have found the same with an older ReadyNAS Remote connection. Strange that it isn't showing up anywhere on the Netgear site as an issue though?
- FramerVJan 30, 2017NETGEAR Employee Retired
Hi vandermerwe,
That would indicate that the ReadyNAS cannot reach our servers.
Might want to setup static DNS on the ReadyNAS (8.8.8.8 or 8.8.4.4).
