vandermerwe
Jan 27, 2017Master
Readycloud services unavailable
Two questions actually, I'm trying to set up Readycloud. Firstly when I toggle on Readycloud in the GUI, "Services unavailable", cannot attach device appears. I have a myNetgear account which is lo...
FramerV
Jan 29, 2017NETGEAR Employee Retired
Hi msavard07,
On your ReadyNAS cloud tab. Do you have (2) green check marks?
vandermerwe
Jan 29, 2017Master
Not sure about msavard, but I dont, one is green, one is red, I would assume msavard is experiencing the same problem?
- MalcolmTJan 30, 2017Apprentice
Seems this may be porttal related. My current ReadyNAS2120 has remained connected and authenticated but I can't access it using the desktop client, and I have found the same with an older ReadyNAS Remote connection. Strange that it isn't showing up anywhere on the Netgear site as an issue though?
- FramerVJan 30, 2017NETGEAR Employee Retired
Hi vandermerwe,
That would indicate that the ReadyNAS cannot reach our servers.
Might want to setup static DNS on the ReadyNAS (8.8.8.8 or 8.8.4.4).
- vandermerweJan 31, 2017Master
I already have static dns setup.
The main readycloud admin user can access the nas using the readycloud portal though, surely this means my nas is connecting to your servers. I do have a problem with invited users not being able to register and therefore unable to access the nas, but I think that may be a different problem.
