KSD
Feb 15, 2017Aspirant
ReadyCloud to MyNetgear migration
Just linked ReadyNas account with the Mynetgear account. and then try to log in with mynetgear account but it shows that this mynetgear account is not linked to any device. 1. How to link mynetge...
KSD
Feb 16, 2017Aspirant
My Ready cloud acocunt should be upgarded to MyNETGEAR acount as I could see "We found the user XXXX is associated with the email address : YYYYYY, Your Readycloud account has already been upgraded to a MyNETGEAR account.
When log in with MyNETGEAR account, it shows that is account is not linked with any device.
I then log in with as adminstrator, I can see the user name and the email address appeared as a cloud user. How to sort out this problem ?
My second queaiton is how to link the deviice (RN102) to a brand new MyNETGEAR account ?
My third quesiton is that can one MyNETGEAR account be used to log in with more than one device. The reason being that I have RN102 devices in the same network but I do not have so many different email addresses to use.
Regards
BingkeX
Feb 16, 2017NETGEAR Expert
Hi KSD,
It seems that your account have upgraded to MyNetgear Account correctly.
"When log in with MyNETGEAR account, it shows that is account is not linked with any device.
I then log in with as adminstrator, I can see the user name and the email address appeared as a cloud user. How to sort out this problem ?"
----Does your cloud account's own home folder have some contents? If it have some contents, you can backup them to a share, then leave your nas from cloud and join to cloud with any valid MyNetgear account. Then check if your issue is ok.
Notes: Leave nas from cloud would delete cloud account's home folder and all email-links and weblinks.
"My second queaiton is how to link the deviice (RN102) to a brand new MyNETGEAR account ?"
----Sure, you can leave nas from cloud and join to cloud with any valid MyNetgear account.
"My third quesiton is that can one MyNETGEAR account be used to log in with more than one device."
-----Yes, one MyNetgear account can access many nas devices, as long as you want. The only thing you need to do is join the nas devices to cloud with same MyNetgear account. Or invite your Mynetgear account to access a share.
For example, you have nasA and nasB, and Mynetgear account1 and account2. You can join nasA and nasB to cloud with Mynetgear account1. Then sign in https://readycloud.netgear.com with account1, then you can access all shares of nasA and nasB there.
Or you can join nasA with account1, nasB with account2. Then sign in with https://readycloud.netgear.com with account1, select nasA's a share to share it with full folder access for account2. After account2 confirm the invitation, sign in https://readycloud.netgear.com with account2. you can access nasB's all shares and access nasA's one share.
"How to set the level of assess (authority) with each mynetgear account"
-----After you invite a MyNetgear account, then you can set share access permission read-write/read-only/Disabled to this invitee user on Manage tab->shared Folders section.
