KSD
Feb 15, 2017Aspirant
ReadyCloud to MyNetgear migration
Just linked ReadyNas account with the Mynetgear account. and then try to log in with mynetgear account but it shows that this mynetgear account is not linked to any device. 1. How to link mynetge...
BingkeX
Feb 19, 2017NETGEAR Expert
Hi KSD,
How to locate cloud account’s own home folder ? Tried to remove cloud user but cannot .a sit says “This device is joined to ReadyCloud.to remove a user, visit ReadyCloud” What should I do ?
-------A user's home folder is a personal share for its own. Only this user have read-write permission to his home folder. When remove cloud user on admin UI Accounts->Cloud users, you get warning info. It means that cannot remove readycloud users on admin UI. You can go to http://readycloud.netgear.com/ and sign in with owner, then go to Manage->Shared Folders, select a cloud user and try to delete it.
What do you mean by leave nas ? (Sign out ?_) Join to cloud means log on with MyNETGEAR account ?
-------Where i say "leave nas" is that on admin UI (https://YOUR_NAS_IP/admin), go to Cloud->Readycloud page, click "Leave" button to leave nas from readycloud. "Join to cloud" means that on Cloud->Readycloud page, turn on the switch from OFF to ON and input your MyNetgear account/password.
Only after you join your nas to cloud with your MyNetgear account, then on http://readycloud.netgear.com page, sign in with your MyNetgear account, you can see your nas device and access it. Otherwise, even though sign in with MyNetgear account, cannot see any device.
- KSDFeb 20, 2017Aspirant
Dear Sir
1. I log in with myNetGEAR account (admin account) , to leave nas, I follow you instruction but come up to a dialog box as follows:
LEAVE !
This device is managed by REadyCLOUD user aaa@yyyy.cc.kk (my Netgear account)
Do you really wan to remove your device from ReadyCLOUD ?
If removed, the following data will be delted
-REadyCLOUD users
-Permissions for ReadyCLOUD users
-Content within the ReadyCLOUD user’ home folders
-Shared links
LEAVE or CLOSE options.
So it is OK to choose LEAVE. (that means I have remove everything to upgrade to my netgear account ?
2. You replies on 16.02.2017 -----Yes, one MyNetgear account can access many nas devices, as long as you want. The only thing you need to do is join the nas devices to cloud with same MyNetgear account. Or invite your Mynetgear account to access a share.
3. Also how to join the NAS device to cloud with same Netgear account ?
4. How to set up an admin netgear account ? or change it ?
Regards
- BingkeXFeb 20, 2017NETGEAR Expert
Hello KSD,
I send a PM to you. Please check it.
Thanks
