uffgnu14's avatar
uffgnu14
Luminary
May 18, 2016
ReadyCLOUD Windows client 1.12 not connecting over cellular network
ReadyNAS Ultra2 Plus
RN OS 6.5.0 (New 18-May-2016)
ReadyCLOUD 1.12.1259.456 for Windows (New 18-May-2016)
Windows 10 Home
Hi
I'm unable to connect with ReadyCLOUD Windows client over cellular network.
Tested with phone connected to PC and using USB-share method.
I disabled firewall but with no success.
Signing in/out to Netgear server seems to work but always getting endless "Connecting...".
Connecting fine with "readycloud.netgear.com" with both local and cellular network.
I don't know if RC client works if connected to a remote network.
Ulf
  • Hi
    I just got the opportunity to test ReadyCLOUD windows desktop client over a remote
    fixed-line internet connection. I got "Connected(VPN) within 1 1/2 minute and listed
    shares could be accessed but no home shares could be seen.
    The RC Desktop client seems working (connection-wise) with local and
    remote (fixed and cellular) network.
    Ulf
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello uffgnu14,
    You should be using the upgraded ReadyCloud account which is the same with myNetgear account, please check if you have done the migration to myNetgear account.
    • uffgnu14's avatar
      uffgnu14
      Luminary
      Hi
      Yes, I'm using same as myNetgear account.
      Ulf
      • JennC's avatar
        JennC
        Hello uffgnu14,
        Can you test if that works when you log in at readycloud.netgear.com?
  • Hello,
    I'm having the Same thing here no WAN on PC
    All it says is "online(VPN Disconnected)"
    Thanks
    • uffgnu14's avatar
      uffgnu14
      Luminary
      Hi mdgm
      Yes, working fine on my local network.
      Unfortunate, I do not have access to a remote network in the near future.
      Can also add that the Mobile client, version 1.2.3 for Android, is working fine on both local (WIFI) and cellular network.
      Ulf
      • mdgm-ntgr's avatar
        mdgm-ntgr
        That's unfortunate as testing on a remote fixed line connection is an important step in isolating the cause of this problem.
ProSupport for Business
