McRob2
Feb 06, 2017Aspirant
Readynas NV V1 Using ReadyCloud
I am looking for some help on how to setup readycloud on a old Readynas NV running firmware 4.1.15. I installed the add on application but I am not able to discover the NAS by pressing the backup...
JennC
Feb 07, 2017NETGEAR Employee Retired
- McRob2Feb 07, 2017Aspirant
I installed readynas remote. It uninstalled my readycloud desktop application. I guess they are not compatable with each other?
Is it possible to connect to a readynas NV and a Readynas 516 and a Readynas Pro at the same time? Each one is running a different level of firmware.
When I installed readynas remote it corrupted my admin password on my readynas 516 and I could no longer get to the admin page. I had to do a firmware update reset in order to log into it again.
Now my windows 10 computer will no longer log into it using file explorer. I can see the device in the network listing but it says windows cannot access device. I can get to the admin page without any problems. Is it possible that installing readynas remote somehow corrupted my windows 10 network settings?
I can still access readynas 516 using readycloud desktop application on a Apple computer without any issues. Is readynas remote available for Apple?
Just a few more things to work thru.
Thanks for the tip on using ReadyNas Remote, I guess.
Just an update to my prior post.
My windows 10 machine just started working on it's own. I changed nothing and it now is able to access the ReadyNAS using file explorer.
I see that windows 10 is not listed as supported for ReadyNAS Remote. Is that going to be a problem?
I still have the question on compatibility between ReadyNAS Remote software and Readycloud Desktop software. Can they both run on the same windows 10 computer.
Thanks.
- McRob2Feb 08, 2017Aspirant
I spoke too soon. My windows 10 file explorer works about 5 percent of the time.
