McRob2
Feb 06, 2017Aspirant
Readynas NV V1 Using ReadyCloud
I am looking for some help on how to setup readycloud on a old Readynas NV running firmware 4.1.15. I installed the add on application but I am not able to discover the NAS by pressing the backup...
McRob2
Feb 07, 2017Aspirant
Just an update to my prior post.
My windows 10 machine just started working on it's own. I changed nothing and it now is able to access the ReadyNAS using file explorer.
I see that windows 10 is not listed as supported for ReadyNAS Remote. Is that going to be a problem?
I still have the question on compatibility between ReadyNAS Remote software and Readycloud Desktop software. Can they both run on the same windows 10 computer.
Thanks.
JennC
Feb 08, 2017NETGEAR Employee Retired
Hello McRob2,
I remember I saw one of our machines have these 2 installed and both can run. But, I don't remember running them at the same time. Just don't get confused that ReadyCloud is for ReadyNAS OS6 which is your RN516 and ReadyNAS Remote is for your legacy unit.
If you are in the same network where the NAS is, you do not need these two. you may simply map the LAN IP address of the NAS on the address bar of your Windows explorer.
