pdaly12's avatar
pdaly12
ReadyNAS Pro 6 - ReadyCloud login rejected
Hi I have a ReadyNAS Pro 6  The firmware has been upgraded to 6.9.1 and it is running really well on that FW.
I have been trying to connect to ReadyCloud, but it appears to be rejecting my Login.
I enter the Username, Password, click connect, and after a minute, it is giving me an error number: '24002000011'
I have 2 green ticks on 'Internet Available' and 'Services Available' . I also have Dropbox enabled and that is running fine.
When I login to ReadyCloud, the ReadyNAS is discovered, so I can manage it.
Can anyone advise?
Here's the syslog:
 User 'ME@MYDOMAIN.co.uk' was deleted.
 Reloaded Samba NMB Daemon.
 Reloaded Samba SMB Daemon.
 Reloading Samba NMB Daemon.
 Reloading Samba SMB Daemon.
 sending signal 15 to procs
 Logon hours         : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
 Bad password count  : 0
 Last bad password   : 0
 Password must change: never
 Password can change:  Fri, 22 Dec 2017 20:25:31 WET
 Password last set:    Fri, 22 Dec 2017 20:25:31 WET
 Kickoff time:         Wed, 06 Feb 2036 15:06:39 WET
 Logoff time:          Wed, 06 Feb 2036 15:06:39 WET
 Logon time:           0
 Munged dial:
 Workstations:
 Account desc:
 Domain:               NAS-EA-12-47
 Profile Path:         \\nas-ea-12-47\ME@MYDOMAIN.co.uk\profile
 Logon Script:
 HomeDir Drive:
 Home Directory:       \\nas-ea-12-47\ME@MYDOMAIN.co.uk
 Full Name:           ME@MYDOMAIN.co.uk
 Primary Group SID:    XXXXXXXXXXXX
 User SID:             XXXXXXXXXXXX
 Account Flags:        [U          ]
 NT username:
 Unix username:        ME@MYDOMAIN.co.uk
 Added userME@MYDOMAIN.co.uk.
 Failed to get usernameME@MYDOMAIN.co.ukfrom db!
 xagent.service: Failed with result 'start-limit-hit'.
 xagent.service: Unit entered failed state.
 rcbrokerd.service: Job rcbrokerd.service/start failed with result 'dependency'.
 readydrop.service: Job readydrop.service/start failed with result 'dependency'.
 Dependency failed for ReadyCLOUD Sync Service.
 Dependency failed for ReadyCloud service.
 Failed to start XCloud agent.
 xagent.service: Start request repeated too quickly.
 Stopped XCloud agent.
 Stopped ReadyCloud service.
 Stopping ReadyCloud service...
 Stopped ReadyCLOUD Sync Service.
1 Reply
  • Retired_Member's avatar
    Retired_Member
    Hello pdaly12
    Can you please send the system log to nsbu_logs@netgear.com?I need to check the xcloud logs to determine the issue.
ProSupport for Business
