GaryW4412's avatar
GaryW4412
time machine password reset
Hi i cannot seem to be able to change the passwords for users or time machine even though i am logged in as admin.
Can anyone help?
Thanks in advance
  • StephenB's avatar
    Can you tell us what NAS you have, and what firmware it is running?
    • GaryW4412's avatar
      GaryW4412
      Hi Stephen
      Thank you for helping im not sure what Firmware it is running on the overview page it says version 6.10.3
      Regards
      Gary
      • StephenB's avatar
        Are you using Active Directory or local NAS accounts?
        If you are using local NAS accounts, what happens when you go to the accounts page in the web ui, select the user, the choose settings, and change the user's password?
        Though I don't use Time Machine, my understanding of the setup is that it simply uses the user's account credentials.
ProSupport for Business
