Cprice83
Apr 18, 2016Aspirant
Unable to discover 104
I have a 104 and it has just updated to 6.4.2 and now I am unable to connect to it via the readycloud portal or via the iOS app. I know lots of people have had the same issues but nothing has worked f...
- Apr 19, 2016
Cprice83 I have fixed the serial number and MAC addresses on this system. They should both be showing correct now.
This system should be able to connect to ReadyCLOUD again now.
Cprice83
I've tried switching readycloud on under cloud on the nas but it won't turn on.
- mdgm-ntgrApr 18, 2016NETGEAR Employee Retired
This is a known issue. I have sent you a PM.
You can send the photo I requested to the email address shown on the page the Sending Logs link in my sig links to.
- JensMankeApr 19, 2016Aspirant
Hi, is this also affecting SMB connection under windows? I cannot find the NAS in the Network (=Windows searching network in windows explorer) and I have to directly access with using the IP of the NAS to get onto the network drive with SMB and it takes for ages until I can put my credentials in.
- mdgm-ntgrApr 19, 2016NETGEAR Employee Retired
JensManke it sounds like your problem is unrelated. Please stick to your thread. I assume your NAS is reporting the correct serial number and MAC addresses?
