Blues11
Feb 06, 2018Luminary
Unable to sign in to ReadyCLOUD
I have not used ReadyCLOUD in quite some months. I tried it just now (from Starbucks) and on the page with the window labeled "Sign in with MyNETGEAR Account" I enter my email address and Password, but it just redisplays the same window with Email and Password changed to the color red. I don't know what that means, bvut I can't seem to get beyond it. I know the password is correct because I was given the option of changing my password.
It send me an email with a link so I changed it.
But I can't log in. Any thoughts on how to fix the problem would be appreciated.
- JohnCM_SNETGEAR Employee Retired
Hi Blues11,
can you try logging in to https://my.netgear.com and see if you are able to login? If you are still not able to login, try changing the password on that site. Please check if you are able to login to the Readycloud portal afterwards.
JohnCM_S
NETGEAR Community Team- JohnCM_SNETGEAR Employee Retired
Hi Blues11,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,JohnCM_S
- Blues11Luminary
John, thank you for the reply. Yes, I can login to my.netgear.com with my Netgear ID, but I had set up a different user email and password specifically for ReadyCLOUD. Now, neither of them will allow me to sign in to ReadyCLOUD. I've tried several one-generation old passwords just to make sure but I've been locked out.
How best for me to resolve this? As the admin should I delete the ReadyCLOUD account that's there and then set up a new one? Or is there a better approach?
Thank you.
