cstern
Aug 31, 2011Aspirant
Bug: router IP not updated when changing ip of network
Hi, Due to some internet provider imposed changes in my setup, I had to change the IP addresses of my LAN from 192.168.1.x to 192.168.2.x. This works fine, except that Readynas Photo II apparantly s...
cstern
Sep 30, 2011Aspirant
cstern wrote: now tried to uninstall and then reinstall - no luck.
Yohdah, maybe you could try to see what happens in your end if you change the network address(?)
I changed the third number in my network from 192.168.1.xxx to 192.168.2.xxx and then it broke down RN-PII
sorry to bump - but I am just curious to know if anything is being done here ;-)
I can add that 1.0.4 does not solve the problem - how about enabling manual setting of the router IP settings?
