cstern
Aug 31, 2011Aspirant
Bug: router IP not updated when changing ip of network
Hi, Due to some internet provider imposed changes in my setup, I had to change the IP addresses of my LAN from 192.168.1.x to 192.168.2.x. This works fine, except that Readynas Photo II apparantly s...
r2_d21
Oct 19, 2011Tutor
1) Warning: Router at 192.168.1.1 does not respond ...
The message "Warning: Router at 192.168.1.1 does not respond to UPnP request." in the first post is second level router. This message is shown when there is two (or more) levels of router to reach internet, and second one from NAS is not responding to UPnP request.
ReadyNAS Photos II daemon trying to configure all router between NAS and Internet. If the first router does not respond to UPnP command, then it treated as error. If the second one doesn't respond to UPnP command, it treat as warning, because most of case this router is built-in to ADSL/Cable modem and all port is pre-set as pass through.
So this warning can be ignored.
2) Error: Fail to access Photos II
Server side has some issue performing this diagnostics item. Please re-run diag if still this error exist.
This error message means router(s) does not forward request onto port 8086 to the NAS.
