dennismi
Aug 10, 2012Follower
Installing aptitude on an Ultra 2
Hi I've recently got an ReadyNas Ultra 2 and so far it's working great... I've enabled SSH access and am trying to install aptitude but it has an unmet dependency: libapt-pkg-libc6.3-6-3.11 ...
InTheShires
Feb 06, 2013Tutor
Apptitude can be done farely easily on x86.
Matty has given an excellent guide and explanation in his post here. viewtopic.php?p=365223#p365223
Works for me, and Aptitude is installed and working fine for me.
MattyShack wrote: See if this helps to clear and reset installed deb packages, then downgrade apt.
Matt
### Update Sources.list ###
mv /etc/apt/sources.list /etc/apt/sources.list.bak
rm -rf /etc/apt/sources.list
sudo sh -c "cat >> /etc/apt/sources.list" <<EOF
deb http://www.readynas.com/packages 4.2.21/
deb http://www.readynas.com/packages 4.2.22/
deb http://archive.debian.org/debian etch main
EOF
gpg --keyserver pgpkeys.mit.edu --recv-key E9C74FEEA2098A6E && gpg -a --export E9C74FEEA2098A6E | sudo apt-key add -
gpg --keyserver pgpkeys.mit.edu --recv-key 54422A4B98AB5139 && gpg -a --export 54422A4B98AB5139 | sudo apt-key add -
gpg --keyserver pgpkeys.mit.edu --recv-key AED4B06F473041FA && gpg -a --export AED4B06F473041FA | sudo apt-key add -
# Setup Root Directory Storage Area
mkdir /root/src
mkdir /root/system
cp /etc/apt/sources.list* /root/system
### Refresh Packages from the APT repository ~ may help remove BADSIG messages ###
# Clear the APT Repositories
sudo killall apt apt-get aptitude
sudo -s -H
apt-get clean
rm -rf /var/lib/apt/lists/*
chmod 755 /var/lib/apt/lists
mkdir /var/lib/apt/lists/partial
chmod 755 /var/lib/apt/lists/partial
rm -rf /var/cache/apt/archives
mkdir -p /var/cache/apt/archives/partial
apt-get clean
# Replace File Locks
rm -rf /var/lib/dpkg/lock
sudo touch /var/lib/dpkg/lock
sudo chmod 640 /var/lib/dpkg/lock
rm -rf /var/lock/aptitude
sudo touch /var/lock/aptitude
sudo chmod 640 /var/lock/aptitude
rm -rf /var/lib/apt/lists/lock
sudo touch /var/lib/apt/lists/lock
sudo chmod 640 /var/lib/apt/lists/lock
rm -rf /var/cache/apt/archives/lock
sudo touch /var/cache/apt/archives/lock
sudo chmod 640 /var/cache/apt/archives/lock
# Fresh download of Repository Packages
apt-get update && apt-get upgrade
# Say 'Y'es to any recommended Fixes. It is OK if either apt-get or dpkg will be upgraded/downgraded
# But, make sure neither apt-get nor dpkg will be removed. If so the aBORT changes.
apt-get -f install
apt-get update
# packages needed after a clean install
apt-get install nano curl
## Note: You may need to downgrade apt-get to apt_0.6.46.4-0.1+etch1_i386.deb for the correct versions of deb files.
# Raidiator 4.2.21 upgrades apt-get to apt_0.7.20.2+lenny2_i386.deb. This may cause conflicts.
# Display apt-get Version
apt-get -v
# Force apt-get and dpkg Downgrade
apt-get --reinstall install apt=0.6.46.4-0.1+etch1 dpkg=1.13.26 dpkg-dev=1.13.26
# I use aptitude most of the time. It does a better job at resolving conflicts.
apt-get install aptitude
