cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all,
Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports.
I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowest machine) would be replaced by the NAS but I'm actually trying to merge some other services onto the box which much luck so far..
One feature I'm working on porting is my Tivo transcoder. Essentially I have a small system that pulls programs off my Tivo, transcodes them and uploads (via WiFi/ethernet) to my portable media player. It means when I get home my media player syncs with my now-playing list so I can watch TV on the train too and from work. Since I work miles and miles away, I don't have time to watch TV at home so it's the only way I can watch TV..
I have the package working on the NAS, and I'm working on the integration with the front end (like managing black-lists and so on). I'd like to bump the speed of the processor but obivously the newer energy efficient <65W intel chips all seem to be 1333MHz FSB. Is this supported on this NAS? I know the warranty is void with this type of fiddling, but that is a risk I'm happy to take.. I also understand you wouldn't recommend an upgrade like this, but I would really like to know if it were possible..
I'll make all the code (mplayer is the driver behind the transcoding) available to anyone if interested.. but it is important to realise this is a Series 1 Tivo and an Archos 705/605 media player, not a common combination..
- MastaMindInitiateOK... just got my NAS up transferred my drives from a Ultra 2.. now I put the drives in my new Ultra 6 Plus.. changed the CPU to a YES X6800 .. and it is up an running with Stock ReadyNas fan. also tried it out with a little mod for pegs with Intel Stock Fan.. both are working. Prefer the Stock ReadyNas fan for profile reasons and can keep the door on. I changed the mem to 2 Gig Ridata ddr 800ghz. Looking at doing an 8GB upgrade. I esentialy want to run a VM off this box on demand. Also want to move my Linux Plex VM to this and see if it will run. Couple of notes. I have had some strange issues when copying either files "MKV" larger then 4GB the transfer speed throttles back from 118MB to 45-60MBs. Anyone else seen this?
Not sure if its a chip issue or something else. Was I supposed to recompile my Kernel for this Extreme Chip? My first post. Getting better with Linux..day by day.. Long time IT admin over 14years building PC and always have to have something to tinker with. :) So glad to find these forums. how are you guys probing the chip and benchmarking.. do I need to install some kind of ssh client on my readyNas? - MastaMindInitiateForgot to give you my fan and temp readings and version.
Radiator 4.2.22
Fan SYS 942 RPM OK
Fan CPU 2083 RPM OK
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 28.5 C / 83 F [Normal 0-85 C / 32-185 F] OK - zijlrTutorHey Guys.
I have an Pro 6 first generation with the 2160 Dual Core 1.8 Ghz.
Understanding that upgrading the CPU voids warranty I have tried to install a 6700 2.66 Ghz SL9S7 cpu.
It did start, run through all steps, acquired ip address and than stopped (power down).
Upon power on again it immediately stopped again.
How can I find out what went wrong ? /var/log/messages does not really give me a clear error so I do not understand why it did not work.
Unfortunately I do not have possibility to check the E6700 itself as my normal machine has an i7 motherboard.
I would expect that the logs would give a clear reason on why it did not work.
Any help is appreciated. - chirpaLuminaryDid you use thermal paste? It is likely overheating and powering off.
- dsm1212ApprenticeAdd me to the list of e7600 upgrades. Took less than 10 minutes to make the swap. System came right up. This is a -200 rev pro6 with Flame 2.0 bios. Picked the cpu up used for $51 delivered. I think it was pulled from a 27" imac. I'll keep the old one in case this was abused but so far it looks good. Temp is 3 degrees cooler than the stock one, but I blew a lot of dust out of the fan and case while I had it open. Running 24x7 I guess its probably a good idea to clean out the dust more frequently!
-steve
# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 23
model name : Intel(R) Core(TM)2 Duo CPU E7600 @ 3.06GHz
stepping : 10
cpu MHz : 3058.990
cache size : 3072 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good nopl aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 xsave lahf_lm dts tpr_shadow vnmi flexpriority
bogomips : 6117.98
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 23
stepping : 10
cpu MHz : 3058.990
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
bogomips : 6117.66
clflush size : 64
power management: - zijlrTutorChirpa, you where right. Not enough paste. Added more paste and now it runs without problems. So Readynas Pro6 gen 1 with 2160 replaced by E6700 also working down here :)
- chirpaLuminaryYay :)
- puntocomTutorThis is a pretty exciting thread. I have an Ultra 6 Plus and I'd like to upgrade the CPU on it. Is there a consensus on that fastest CPU I could put in here without needing to modify the cooling significantly?
I also checked the logs and found out that I have an older BIOS: 10/03/2008 FLAME6-MB V1.6
How can I get this newer BIOS everyone is talking about? - chirpaLuminaryUltra 6 Plus that has a FLAME6-MB board will support the same CPUO as the ReadyNAS Pro mainly in this thread. An E7600 may be trial and error, but lower models should work fine.
- puntocomTutorCool, thanks for the info. I'll see if I can't find an E7500 somewhere just to be safe. I saw in another thread that you had that newest BIOS available to writing to a USB drive to flash the ReadyNAS, do you still have it?
