cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all,
Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports.
I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowest machine) would be replaced by the NAS but I'm actually trying to merge some other services onto the box which much luck so far..
One feature I'm working on porting is my Tivo transcoder. Essentially I have a small system that pulls programs off my Tivo, transcodes them and uploads (via WiFi/ethernet) to my portable media player. It means when I get home my media player syncs with my now-playing list so I can watch TV on the train too and from work. Since I work miles and miles away, I don't have time to watch TV at home so it's the only way I can watch TV..
I have the package working on the NAS, and I'm working on the integration with the front end (like managing black-lists and so on). I'd like to bump the speed of the processor but obivously the newer energy efficient <65W intel chips all seem to be 1333MHz FSB. Is this supported on this NAS? I know the warranty is void with this type of fiddling, but that is a risk I'm happy to take.. I also understand you wouldn't recommend an upgrade like this, but I would really like to know if it were possible..
I'll make all the code (mplayer is the driver behind the transcoding) available to anyone if interested.. but it is important to realise this is a Series 1 Tivo and an Archos 705/605 media player, not a common combination..
- fastfwdVirtuoso
dsm1212 wrote: Are your four drives in dual redundancy? Mine are so it's really a three drive config. Maybe a drive cache size difference?
Single redundancy for me. The "-T" test reads from the portion of your main RAM that Linux uses as a disk buffer; it just tests how fast Linux's disk-cache algorithm running on your CPU can read data from your RAM. The drive isn't even accessed during the timed portion of the test, so nothing about the drive's performance -- including the size of the drive's onboard cache -- should affect the result of the "-T" cached-read test. - soremaniacAspirantMmh i tried it with a Q6600 (4Core) in After the BIOS Update the ReadyNAS 6 worked perfekt. So i went an took my ReadyNAS PRO with the Q6600 i get this (Even After the BIOS Update).
Sat Mar 2 18:58:21 CET 2013 System is up.
Sat Mar 2 18:14:26 CET 2013 System is up.
Sat Mar 2 18:01:01 CET 2013 VBAT power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:01 CET 2013 3VDUAL power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:01 CET 2013 VCC1_05 power is out of normal range [expected: 1.04 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 VCC1_5 power is out of normal range [expected: 1.50 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 VCC1_25 power is out of normal range [expected: 1.25 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 VCC3 power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 AVCC power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 DDB18 power is out of normal range [expected: 1.80 current: -0.00].
Sat Mar 2 18:00:40 CET 2013 Gerät fährt herunter
Sat Mar 2 18:00:40 CET 2013 Bitte schließen Sie diese Browsersitzung und melden Sie sich nach dem Neustart mit RAIDar wieder an. Das System fährt jetzt herunter...
Sat Mar 2 18:00:33 CET 2013 Fan 1 has failed (SYS -1 rpm).
Sat Mar 2 18:00:33 CET 2013 VBAT power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 3VDUAL power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC1_05 power is out of normal range [expected: 1.04 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC1_5 power is out of normal range [expected: 1.50 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC1_25 power is out of normal range [expected: 1.25 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC3 power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 AVCC power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 DDB18 power is out of normal range [expected: 1.80 current: -0.00]. - soremaniacAspirantNow i put back in my E6600 and it Works with no error Messages but Lot slower (put still faster as the Org. CPU). Is there a change to get it to work with the Q6600? What are These error Messages mean? How i cut fix that?
Thx 4 your help - chirpaLuminaryWeird. I though those were read off the board, they are power voltages. Maybe the chipset doesn't work well with that CPU, causing some issues.
If the system appears to work otherwise when you see those errors, I can provide a boot script work around, to have the system not log those errors. - chirpaLuminaryOn boot up, RAIDiator firmware looks at the system type, and builds a layout for monitor_enclosure (health check program, adjusts fans, sends alerts). Easiest way to deal with your logs is to modify that layout (saved in ramdisk) and restart moitor_enclosure. I haven't tested this out, but it should hopefully work, maybe needing a few tweaks:
# cat /etc/rc2.d/S02readynas_enclosure
This removes the voltage lines from the layout, then restarts the service. So it won't know to read the voltages, causing logs/email alerts. If you look at /ramfs/enclosure.cfg, you can also see references for the temp/fan sensors.
#!/bin/bash
sed '/^vol/d' /ramfs/enclosure.cfg > /tmp/enc.$$$
mv /tmp/enc.$$$ /ramfs/enclosure.cfg
killall monitor_enclosure
sleep 1
/frontview/bin/monitor_enclosure
I had to do a similar boot script for my retro-fitted Repertoire. I replaced the Sparc board with x86 (Ultra4 board). Since the Repertoire chassis has no fans, the system would complain that the fan has failed. The script I used there would tell the system there was no fans to monitor (over the default Ultra4 layout), so no more alerts would occur. - dsm1212Apprentice
Well 4 drives should do a little better than 3 and one of my drives is a cool model (an odd 5900rpm I believe), but it seems hard to believe that is all of the difference. Could you post the output of hdparm -i /dev/sda? I'd like to see if there is anything special your drive can do. Maybe the fact that I have 3 different drive models triggers some poor md behavior due to cache size mismatches or something.
One thing odd I noticed is that when I run the test of /dev/c/c my USB drives all wake up. I've got 4 of them attached to a USB hub. Maybe I should try disconnecting them all?
steve - soremaniacAspirant
chirpa wrote: There may be even newer BIOS now, but I don't work there anymore to know that.
You can try running this add-on (install in FrontView, don't need USB boot anymore), which will update to the latest I had at the time: http://www.readynas.com/download/addons ... .5-x86.bin
That v0.5 add-on provides these BIOS versions:- Ultra2/ReadyNAS-ProUltra2 (1102/v1.8)
- Ultra4/ReadyNAS-NVX-V2 (0823/v1.1)
- Ultra6/FLAME6-2 (0610/v1.1)
- Pro(6)/FLAME6-MB (0726/v2.0)
Sorry if that is a old Question, but How i can see that the Firmware is Installed?
Thx - chirpaLuminaryCheck bios_ver.log in the System Logs download.
- fastfwdVirtuoso
dsm1212 wrote: fastfwd wrote: The "-T" test reads from the portion of your main RAM that Linux uses as a disk buffer; it just tests how fast Linux's disk-cache algorithm running on your CPU can read data from your RAM. The drive isn't even accessed during the timed portion of the test, so nothing about the drive's performance -- including the size of the drive's onboard cache -- should affect the result of the "-T" cached-read test.
Right, your drive performance is none of the difference in the -T cached-read test, since that test only measures the speed at which data travels between the NAS's RAM and the NAS's CPU. - dsm1212ApprenticeWell, it seems like hdparm is not very accurate. I ran a more simple test and I get similar IO rates to the drive, but the reads from the linux cache are much higher than what hdparm reports. I'm still suspicious as what the heck hdparm does with my USB drives.
This is what I did:
# First create a 1GB file:
dd if=/dev/zero of=gigfile bs=1M count=1000
# Flush the file to disk
sync
# purge the cache
echo 3 | sudo tee /proc/sys/vm/drop_caches
# see the cache is mostly empty
free -m
# time the physical read case
time cat gigfile > /dev/null
# see that the big file is now in cache
free -m
# time the cache read
If I divide 1000 / by the elapsed time I get a physical read number similar to hdparm. For me about 300MB/sec. I think the difference there is probably the drives I'm using. But for the cached read I get over 4000MB/s so I don't understand why hdparm reports only 1900MB/s.
By the way fastfwd, what os rev are you running? I'm running 4.2.21.
thanks,
steve
