cpitchford's avatar
May 22, 2009
More on CPU specs of the ReadyNAS Pro
Hi all,
Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports.
I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowest machine) would be replaced by the NAS but I'm actually trying to merge some other services onto the box which much luck so far..
One feature I'm working on porting is my Tivo transcoder. Essentially I have a small system that pulls programs off my Tivo, transcodes them and uploads (via WiFi/ethernet) to my portable media player. It means when I get home my media player syncs with my now-playing list so I can watch TV on the train too and from work. Since I work miles and miles away, I don't have time to watch TV at home so it's the only way I can watch TV..
I have the package working on the NAS, and I'm working on the integration with the front end (like managing black-lists and so on). I'd like to bump the speed of the processor but obivously the newer energy efficient <65W intel chips all seem to be 1333MHz FSB. Is this supported on this NAS? I know the warranty is void with this type of fiddling, but that is a risk I'm happy to take.. I also understand you wouldn't recommend an upgrade like this, but I would really like to know if it were possible..
I'll make all the code (mplayer is the driver behind the transcoding) available to anyone if interested.. but it is important to realise this is a Series 1 Tivo and an Archos 705/605 media player, not a common combination..
  • Changed the standard processor E2160 to E7600. Memory 4GB, not changed
    WAS
    NAS:~# cat /proc/cpuinfo
    processor : 0
    vendor_id : GenuineIntel
    cpu family : 6
    model : 15
    model name : Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz
    stepping : 13
    cpu MHz : 1795.522
    cache size : 1024 KB
    /dev/c/c:
    Timing cached reads: 2526 MB in 2.00 seconds = 1263.67 MB/sec
    Timing buffered disk reads: 1108 MB in 3.00 seconds = 369.07 MB/sec
    NOW
    /proc/cpuinfo
    processor : 0
    cpu family : 6
    model : 23
    model name : Intel(R) Core(TM)2 Duo CPU E7600 @ 3.06GHz
    stepping : 10
    cpu MHz : 3058.978
    cache size : 3072 KB
    /dev/c/c:
    Timing cached reads: 4106 MB in 2.00 seconds = 2054.13 MB/sec
    Timing buffered disk reads: 1566 MB in 3.00 seconds = 521.82 MB/sec
    SYS 917 rpm ОК
    CPU 1985 rpm ОК
    temp SYS 57
    temp CPU 39
    Work well!
  • I tried an E6850 on a Pro6 with mobo Flame 6 Version 1.1.
    It didn't boot.
    The E6850 is 3.00ghz core 2 duo 4MB of L2
    I returned to the stock E2168 until I try an E6700.
    E18 is 1.8ghz Pentium dual-core.
    If the E6700 doesn't work on this mobo, I'd appreciate a heads up.
  • Dear All:
    Trying to breathe new life into my ageing Pioneer Pros (one is for backups, one is a video streamer)
    After successfully upgrading my ReadyNAS Pro Pioneer Edition to e6700 tried an e7600, the display says ReadyNAS, the fan(s?) blow at full speed and nothing happens.
    I have two NASes, and I tried two CPUs and both failed.
    The motherboard says Flame ver 1.1 and the yellow square sticker says "FA5"
    My obvious concern is that the CPUs might have arrived dead.
    However, reading through the forums, I recall Chripa mentioning that earlier boards may not support later CPUs.
    Any idea whether this particular board revision should support the e7600?
    Will a BIOS upgrade potentially fix this problem?
    If so, how do I perform one? I understand this is different from the RAIDiator firmware upgrade (I am of course running the latest)
    Thanks you so much for your input.
    Chirpa - pls help!!!
    • flip68's avatar
      flip68
      Hi MDGM,
      I have a Pro 6 (-100) version where the bios_ver.log shows 10/03/2008 FLAME6-MB V1.6 as my current BIOS.
      I am currently running OS 6.2.4 already successfully with the stock CPU, but now I would like to upgrade the CPU to either a Q6600 or an E7600.  I understand I need to upgrade the BIOS to at least V2.0.
      I understand there is a BIOS UPDATE PACKAGE_0.5.bin that CHIRPA has posted in this thread, but .BIN files are not recognized by OS6 (debian only?)
      You briefly mentioned the process to get the BIOS updated by doing some type of conversion, but it wasn't clear to me. If you could provide some detailed steps to do so, I would greatly appreciate it!
      Lastly I'm still torn between the Q6600 CPU or the E7600 CPU.  My intent here is to host a Plex Media server for the home as well as my Logitech Media Server.  Anythoughts on which of these two would be better for these type of servers?
      Thank you!
  • Dear mdgm -
    Thanks for a quick response and direction.
    Updated the BIOS per your instructions and the CPU is now recognized.
    One last question - does it really make practical sense to install more RAM, or are benefits marginal? I have the stock 1GB I assume. The one NAS is used for video streaming, but if I figure out a way to start transcoding blu-rays on the fly, would more RAM be helpful?
    Thanks,
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    CPU is the main thing. Monitor the memory usage and if the swap isn't being used then a memory upgrade would likely only have marginal benefit.
    You can use e.g. Plex to transcode 1080p MKVs.
  • Retired_Member's avatar
    Retired_Member
    Not sure if this thread is dead but I just did some looking through it and wanted to share some feedback for the next one.
    Pro 6 stock FLAME 2.0 running 6.4.1.  root@NAS:/# hdparm -t -T /dev/sda
    ORIGNIAL CONFIG: E5300 with 1GB PC2-6400 800MHz Memory
     Timing cached reads:   2120 MB in  2.00 seconds = 1059.80 MB/sec
     Timing buffered disk reads: 456 MB in  3.00 seconds = 151.91 MB/sec
    NEW CONFIG: E7600 with 1GB PC2-6400 800MHz Memory
     Timing cached reads:   2932 MB in  2.00 seconds = 1465.82 MB/sec
     Timing buffered disk reads: 450 MB in  3.01 seconds = 149.47 MB/sec
    FINAL CONFIG: E7600 with 2x2GB PC3-8500 1066MHz Memory (Crucial CT2KIT25664AA1067)
    Timing cached reads:   3808 MB in  2.00 seconds = 1904.03 MB/sec
    Timing buffered disk reads: 466 MB in  3.01 seconds = 154.86 MB/sec
    Not sure why the numbers are low with hdpram compared to some other processors but the apples to apples means I am running 2x here on cashed reads and 1080p Plex videos are running better.
ProSupport for Business
