xren
May 24, 2017Follower
Need help with Surveillance on readyNAS 204
Hi
I need help to get surveillance app work on my readyNAS 204, The app is installed from readynas app store without any issue but however when I click the launch button or access it on port 5100 it returns a php source page ( see the screenshot below). it seems to me that there is no php installed on my system. I just updated to 6.7.3 but the problem still the same.
i would really appreciate any help
- JennCNETGEAR Employee Retired
- RdhrdhAspirant
I'm in the same boat with my 212. I've used Chrome, Edge, Firefox and IE.
- viperhansaVirtuoso
Depending on your system, just install the correct PHP add-on from app-store..
You can find it here: Netgear NAS apps
// Hans
- Nov 24, 2016Retired_Member
