zennit
Feb 24, 2012Aspirant
perl issues on duo
trying to install gitolite on my readynas duo which uses perl but getting Can't locate English.pm
how would I go about adding this to perl?
Do I have to apt-get some modules?
- zennitAspirantI installed the php addon but i'm not using it so I have it disabled, gitolite is written in perl. Perl core seems to be the problem, does the readynas have a stripped down version of perl core?
- mdgm-ntgrNETGEAR Employee RetiredThe PHP add-on from WhoCares? or another one? What version?
- zennitAspirantWhoCares
- mdgm-ntgrNETGEAR Employee RetiredIf you have a current version of his add-on you shouldn't be able to disable it, I think. What version of the add-on do you have?
- mdgm-ntgrNETGEAR Employee RetiredAlso if you enable it you can search for php5-ldap on the PHPInfo page (think this is found at http://ip.address.of.nas/PHP5/phpinfo.php) and see what it has to say about it.
- mdgm-ntgrNETGEAR Employee RetiredVia SSH, what do you see if you do the following?:
dpkg -l | grep php5-ldap - zennitAspirantv5.3.8-rnsparc-1.4.1 on the frontview addons I don't have it ticked
- zennitAspirantiU php5-ldap 5.3.8-1.1 LDAP module for php5
- mdgm-ntgrNETGEAR Employee RetiredSo you have that module listed and also found by dpkg command I mentioned above?
Can you also try this:
dpkg -l | grep libsasl - WhoCares_MentorThe php5-ldap thingy is a "known issue" but not the source of the current problem, really.
Back on topic: According to my crystal ball (package search on Debian ;)) the English.pm file should be part of the the perl-modules package. Or at least it is with newer Perl versions. What doesdpkg -S English.pm
tell you?
-Stefan
