chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
chirpa
May 08, 2013Luminary
Using the prep addon first automates the factory default process. So installing that addon, then the firmware, it will reboot,update,factory default. Otherwise without the addon, only the firmware image, would seem to hang after the update, requiring a manual factory default with the boot menu (physical access).
