chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
JMehring
Sep 18, 2013Apprentice
If you were to install OS 6 on an Ultra 6 Plus, would you be able to then use 4TB disks instead of the maximum 3TB that I can use on 4.2?
