chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
mdgm-ntgr
Sep 18, 2013NETGEAR Employee Retired
Well you could give it a try. If you don't like it I can give you instructions to downgrade back to 4.2.x
Do be aware also that a downside of encryption is that it can make data recovery more difficult so if you store important data on encrypted volumes you should especially make sure you backup that data e.g. to an encrypted volume on another ReadyNAS.
