chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
mdgm-ntgr
Jan 10, 2014NETGEAR Employee Retired
1. You need to use the modified image or modify the ReadyNASOS-6.1.5-x86_64.bin yourself. The modified image appears to 4.2.x to be a 4.2.x firmware image so it accepts it. If you change the R4toR6 link to say 6.1.5 not 6.1.4 you can download one to go straight to 6.1.5. I didn't update the links to point to that though due to the issues some have had on 6.1.5.
Once you are running ReadyNAS OS you need to use the standard firmware image for future updates.
2. The new OS is very different so be careful what you restore. Best to make as many changes as possible manually. It's possible you might need to use systemd to start custom services. The apps sdk should give some clues as to how this works: http://apps.readynas.com/pages/?page_id=68
3. The SSH hack would still be needed I think for the 6-bay Pro. Or if you have a VGA header cable you could modify the BIOS setting to get the BIOS to control the fan speed.
If you're not happy with the new OS I can help you downgrade back to 4.2.x
