chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
tony359
Mar 30, 2014Apprentice
Ok. After a little experimenting I managed to install OS6 on my Pro6, downgraded back to 4.2.26 and back to OS6. I have tweaked the fans and they work fine.
My only problem is: if I transfer content, the unit disappears after a while, and windows come up with an error. Transfers are also very temperamental: NAStester shows maybe a good average but out o 5 transfers it may be that 2 are 110MB/s and 2 are 60MB/s. Back to 4.2.26 and tested with the same disk I have much more stable transfers - and the connection is stable.
Anything I may be missing?
Thanks
Thanks
