chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
michaelvec
Mar 30, 2014Tutor
Hi Tony,
thanks for the quick reply. Yes, using root does the trick. Thanks!
All: Please keep in mind to use user root instead of admin when using ssh.
Hi mdgm,
not sure if I can simply upload this to the Pro 6 but will look into it.
Thanks so much
Hi mdgm,
Thanks so much
