chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
tony359
Mar 30, 2014Apprentice
Yes you can. After you are on 6.x you can upgrade to another 6.x. I've just done it and so far so good. It's transferring ok, even though I'm not convinced by the speed.
The fan speed is finally ok, but I've lost the CPU speed. Temps are still off.
