chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
sgirard
Apr 15, 2014Tutor
michaelvec wrote: same here.
When from 4.2.26 to 6.1.6 per R4toR6 image.
Transfers from my computer back to the NAS has 100 to 40 MB/s and often stops.
Fan are not loud but NAS website doesnt indicate fan rpms correctly (5355). temp ok but temp graph doesnt seems to work.
Enabled SSH but ssh session terminates after successful login with putty.
login as: admin
admin@nas01's password:
Welcome to ReadyNASOS 6.1.6
Anybody who got some of these issues resolved?
Hi there Micheal, I am getting this same behavior too. Thought I would upgrade to 6.1.7 tonight because I read somewhere it may reduce this problem. Unfortunately, I cannot access my Web interface to do the upgrade VIA web interface. :( Meanwhile, I am able I can access my shares and connect via SSH.
Does anyone have any suggestions that I can try. I have already tried rebooting the unit a number of times.
Cheers
Shawn
